This custom tile creates a place holder which will display a random image, or you can select the slide show option with transition effects. Add the tile in a dashboard to view random pics of your vacation, family, inspiration or simply use as a screen saver.
In addition to the slide show options, you can select a ‘tap’ action to view the next image or open another dashboard (useful if used as a screen saver/photo album), and an optional clock.
https://i.imgur.com/VfPEObs.mp4
https://i.imgur.com/0G5Quhk.mp4
Setup
Upload your images to a hosting provider.
NOTE: The Custom Tile currently includes a set of images (Bing Gallery) -
Click the import button above to install the Slide Show Tile into your SharpTools account and click Save.
Add the tile to your dashboard, click edit, and enter the required (**) information (URL Path, Image/File Names) and optional display options in the tile settings.
NOTE: Enter image/file name, including the extension (e.g., .jpg, .png), separated by a comma.
Example: image1.jpg,img2.jpg
- ** Only needed if you are using your own images - Leave blank to use the provided images.
Options include:
- Image Size (e.g., cover, 75% 75% (percentage), 100px (pixel), contain)
- Image Opacity, Image Blur
- Shuffle Images Every… (minutes)
- Slide Show Transition (Fade, Zoom, Spin, Slide, Tumble (android/chrome only), None), Transition Speed
- Tap Action (Dashboard, Next Image, None), Dashboard ID, Open dashboard Full Screen (True/False)
- Show Clock, Clock Font Size, Clock Color
Tips:
Edit the tiles style to:
- Transparent Background
- Turn Shadow OFF
