I have a API call that returns the information below -
My question is how can extract the 5.24 part, so I can set it to a variable
Im ok with the variable part just stuck on how to get the 5.24 part out
Thnaks
Thnaks
Can the API return JSON instead of XML? That would make the parsing much easier.
Otherwise you could try using an expression to find the opening and closing <balance>
tag and get the content between them.
Something like:
text ="<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n<xml><result>0000</result> <errortext>Success</errortext><balance>5.24</balance><type>Prepay</type> <currency_symbol>£</currency_symbol> <currency_type>GBP</currency_type> </xml>\n"
start = indexOf(text, "<balance>") + 9
finish = indexOf(text, "</balance>")
substring(text, start, finish)
Of course in your example, you could use $context.response.data
in place of the hard-coded text value from my example.
That’s worked great, Thanks
