You can do this with the SharpTools Rule Engine. You can create a rule and then run that rule directly from your dashboard. ![]()
Sometimes I’ll create a rule with just a single action with a custom command on a device just so I can run it from the dashboard.
@james do you still have Echo Speaks setup?
