Just to add use case… I really don’t want to have to make this as a rule with all of these different triggers and actions that’s 11 if_conditions with 6 actions each
As for how it would look, I think the drop down menu selection option shown earlier from webCoRE would work really well. Not sure on how things are setup but if the concern about devices with different attribute types can’t be resolved easily maybe adding another option such as “Multi Device”:
As it seems we’re not being understood clearly, here’s an example of using mutiple devices grouped in a WebCoRE piston, that takes 10 minutes to do, and the same in a Sharptools rule that takes a couple of hours, gave me considerable arm ache…
Still trying to figure out how to recreate your ‘battery & device status’ piston you discussed a while back on your channel. It’s a grape in webCoRE, but I’m struggling to grasp a method in SharpTools. I’m sure hoping that multiple device lists and setting temporary variables on the fly are in future works.
Just wanted to share an update that we’re actively working on this in our development environment…
In the video above, once I select a device, the list automatically filters to other devices which share the same attribute. We’re still working on refining things, but expect to release the multi-device triggers to beta first, then will continue work on multi-device commands for a later release.
