Hi @Charles_Kyle, Happy New Year to you as well. That’s a great idea for rule, but it depends on if the device reports the failed attempt to the hub. Can you share what Schlage lock you have, what hub and what device handler you use, so I can check further for you? Thank you.
I have a Schlage BE468/BE469 Lock on a Hubitat Hub. I am using the native handler within Hubitat.
Under Current Status
Current States
battery : 89
codeChanged : deleted
codeLength : 4
lastCodeName : unknown codeNumber: 2
lock : unlocked
lockCodes : {}
maxCodes : 30
I played around with entering an incorrect code and then compared it to the above current status. It does not look like anything changes, therefore probably not something that could be done
Yeah from the available states, it doesn’t look like the DTH reports the invalid code event. May be something to be posted in Hubitat forum if there’s another DTH does that.
