Scott-
Most of the MyQ integrations I’ve seen have some form of ‘virtual’ garage door that is backed by a physical contact/tilt sensor connected to your hub. It sounds like you changed out the physical contact sensor which helps support the MyQ garage door device, right?
Which device is reporting open in SharpTools?
One helpful troubleshooting tool is to check the reported device details directly rather than in your dashboard. From your SharpTools.io User Page, you can tap the ...
next to a location, then scroll down and tap a device to view it’s details.
I would double check that the same device is being compared between SharpTools and Hubitat as well. From the SharpTools device details screen, flip the Advanced toggle in the top-right corner on and make the same “Thing ID” for the same Hub ID / Location ID is being compared.
