@josh thanks for redacting that. I added the wrong image ![]()
This rule works well for monitoring a particular device. The ‘Bearer’ is the ‘YOUR_PAT’ mentioned be @Chris_C and the other blanked out bit is the device ID. Again @Chris_C mentions how to find this.
The main downside is that you need a separate API call for every device, so I have compromised by only checking the main devices (or ones that I have noticed do not come back online after an outage).
What is the 200 status?
200 status means the command was successful.
Other status (eg 400) can indicate things like incorrect or unknown device ID or PAT. I put it in there just to make sure I only check the status if the command was successful. It may not actually be required.
