Life360 Live Map
Thanks just_jake. That would be hugely helpful. I’m aware of Tasker but haven’t used it directly in the past. This change by Life360 is frustrating. They abandoned their Alexa skill last year too. There was a key thing that was awesome with that skill. I was able to create a routine where I could ask Alexa where either of my kids were and Alexa via the Life360 skill would tell me their location. I miss that :-).
They killed the integration for Google as well. I miss asking where is my family.
I use Geofency on iPhone - works very well. FYI - the Life360 connection still seems to run on my Hubitat despite all of the other things working. There is a long thread on this and I can’t figure out why it still works - even after I switched to a new hub, etc.
UGH - it doesn’t seam that Geofency is supported officially or unofficially for Smarthings. THX!
@josh I wanted to see if we could reboot this integration using the GPS location in a variable? I have this information exposed through a number of ways in Hubitat and Home Assistant. Would it be easy to update this custom tile to specify a variable and then use that to update the location?
This tile is specifically designed for integration via the Life 360 API, but I’ve gone ahead and updated what we formerly called the ‘Hubitat Map Tile’ to take advantage of the new Access to Things in Custom Tiles feature so it can be used with any device in SharpTools which exposes a latitude and longitude attribute:
:world_map: Geolocation Map Tile (Latitude/Longitude)
Hey there. I figured I’d check in with you on this :grinning:. How’s it going with the custom tile that you’re building? I’m very curious as I relied on that Life360 integration.
Yes, I’m be procrastinating on this project a bit. I have the map section done, I just need to finish the SharpTools integration.
Thanks. I’m happy to be a beta tester for you :slight_smile:
Hi there
Just wanted to see if this was working now. i followed the link to get the key but that link doesn’t seem to work anymore
cheers
It looks like Glitch, which was hosting the small authorization page, shut down after they were acquired by a bigger company. I downloaded the code and started porting it to another host, but it looks like Life 360 has also blocked this unofficial authorization approach that community integrations were using.
From what I can tell, many community members have abandoned Life360 altogether, voicing frustrations about Life360 being anti-consumer – especially for people who were paying for Life360.
From a brief review of some of the smart home communities, it looks like many people are moving to alternative OwnTracks or smart-home platform native geofencing solutions.
The good news is that if your solution of choice integrates with your smart home hub of choice and exposes the latitude and longitude as attributes, you can use it with the Geolocation Map Custom Tile.
