Are you interested in the Battery or Offline status? For the battery, there might be an alternative approach where you setup rule(s) to track the battery status directly instead of using this special aggregation endpoint.
I went with this:
BatteryMonitor
BatteryMonitor SmartApp for Hubitat
Version 1.1
Author Brandon Gordon, larry kahn
I was curious about this so I enabled an existing rule that incorporated the health check from over a year ago. It returned a 403 error which I believe indicates an authorization issue. It did not work, so I donāt think my existing PAT is grandfatheredā¦
From the linked thread, it looks like existing PATs from before December 2024 should still work:
An HTTP 403 means Forbidden. In other words, their API understands your request but refuses to authorize it due to a lack of permission for the expected resource ā the most common case for this is not having one of the required permissions (eg. List and See All Devices) which you would have needed to explicitly granted when the PAT was originally created.
Normally if the token was fundamentally invalid, I would expect an HTTP 401 which means Unauthorized and is commonly used when no credentials are supplied or the credentials are invalid / expired.
Hi Josh,
Itās the āofflineā Iām interested in. I already have a SmartThings routine to check battery status but I canāt do offline checks.
Thanks,
Bob
