This is a request to be able to insert new code segments anywhere in a rule. The user would be provided a “+” or “Add” button between each sectioin of code in an existing rule.
it’s easy to delete code in the middle of a rule, but inserting code is not at all easy. It must be added at the bottom of the rule and then moved up to the desired location. If it’s a long section being moved it’s really quite difficult to do.
