GE Enbrighten light switches SmartThings Hub
I started using SharpTools in 2023 with my SmartThings hub and Enbrighten GE smart light switches. When the announcement was released that API usage was too high, I wanted to add scenes to reduce my usage. To do so, I created scenes in Smartthings app, then disconnected my “home” which had all my “things” and re-added it. The new scenes appear along with all my “things” (light switches). All my rules are still present and the “things” on my dashboard work successfully when I click them. Lights turn on and off from the dashboard so I know Sharptools is working.
However, none of my Rule Engine rules are working now. I checked the logs and they don’t trigger at all. So, I’m wondering if Event Tigger - Select Attribute should change? Or Select Operator updates and is something different than down_2x? Or do i need a new driver for my switches?
Here is an example of one rule that should allow my wife to double tap down to turn the lights to 10 percent dim level.
EVENT TRIGGER - DEVICE
SELECT THING
  • Light Switch
SELECT ATTRIBUTE
  • button
SELECT OPERATOR
  • updates and is
  • down_2x
FLOW
SELECT THING
  • Light Switch
SELECT COMMAND
  • setLevel
INPUT ARGUMENT 1
  • #10
Hey Danike, disconnecting a location should only be used if you want it permanently removed from SharpTools. The disconnect dialog warns about that because it can leave Rule Engine event subscriptions in a bad state, which matches what you’re seeing: dashboard tiles still work, but the rules never fire.
For the rules that stopped triggering, you don’t need to rebuild them. The fastest path is to tap the … next to each rule in the list, disable it, then tap … again and enable it.
If you do it from the editor instead, toggle the rule to Disabled and save, then open it again, toggle it to Enabled, and save.
If anything still doesn’t fire after that, from your User Page tap the … next to the location name, scroll down, and tap Repair. Then double-tap down on one of the Enbrighten switches and check the Rule Logs.
Hey Sam, clicking edit on rules and disabling then re-enabling did not fix it however repairing the “home” connection did! Thank you very much. I shared the logs below showing it successfully registered the double tap from switch.
