Fan as Switch Tile doesn't turn on (Error Sending Command) , but does turn off
I have another fan that won’t turn off using a sharptools tile. It’s a Tuya integration via Home Assistant. I’ve used the cycle speeds and when it gets to off, it just skips Off and goes right to Low. I’ve also tried changing Layout to Switch and it will turn Off, but when I try to turn it on, it says Error Sending Command and doesn’t turn on. Any idea how I might be able to get this working correctly? All works fine in Tyua app and in Home Assistant.
A post was merged into an existing topic: Fan not responding to “on” command
