I need to change a non-variable tile’s style dynamically from my smart home hub. I understand that there’s a way to set a variable dynamically with an HTTP trigger, which is great, but I don’t see any way to set a tile’s styling based on that variable unless the tile is a variable tile. Am I correct that this would need to be a new feature request, or did I miss some way to do it now?
Use case: My smart home hub (Hubitat) changes my tablet’s dashboard background with the weather, which means that the main background color changes dynamically with the weather. I’d like for my smart home hub to trigger (e.g., using the existing HTTP trigger feature) switching a tile’s coloring between black and white.
