Should using a dashboard tile on a dashboard that has a different base tile size than the dashboard it’s pointing to cause problems?
Wait! Even I don’t understand what I wrote. Let’s try this example:
Dashboard 1 has a base tile size of 100px. It includes a dashboard tile that points to Dashboard 2.
Dashboard 2 has a base tile size of 50px. It includes a dashboard tile that points to Dashboard 1.
Question:
Will there be a problem with either of dashboard resizing when switching between them? If the answer is “Should work OK”, I’ll try to quantify what I think I’m seeing.
