I am very new to SharpTools. Trying to move my rules over from WebCore.
I am trying to make a Rule for when “Virtual Switch” Changes to On, and it’s after Sunset, Turn a Light On.
I can’t seem to see how to do this… If I add the Virtual Switch to a Trigger I can select “Changes to”… If I add Time to a Trigger I can Select Sunset…
But if I add either of those two options under an IF statement, I can not choose “Changes To” or “Sunset”…
I see the condition section says if ANY of the triggers are met it will execute… I need BOTH to be met…
Is this possible? Am I overthinking something?
Seems like this would be a common statement.
Thanks in advance for any help you may be able to provide.
Triggers occur when any of the triggering events happen
Conditions restrict the rule flow
As for the difference in language between triggers and conditions, this is basically the difference between events and states. When a value triggers a rule, we say that the value ‘changed’. Whereas when we check the current value of a device, we say that it currently ‘is’ that value. Otherwise, they’re both equality checks.
So in your case, I suspect your rule would look something like the following:
Thank You…
So easy… I tried it that way, but I never clicked on Time, Because I was looking for the Sunrise & Sunset buttons… Like it is in the Triggers section…
