Anyone else have this issue or know how to fix it: When I go to sharptools.io the login buttons arent clickable. The only things that are clickable are the hamburger menu in the top left and the Help question mark in the bottom right. Same behavior in Edge and Chrome. I can get around it by using Edge’s InPrivate mode or Chrome’s Incognito mode.
Do those browsers have any plugins installed? Keep in mind that Edge is based on Chromium now, so it could have migrated settings or plugins without you realizing it.
Otherwise you could try clearing your cache/data in each browser as that’s effectively what incognito is doing (running the webapp without cookies, local storage, etc)
Yep, an extension was causing this issue. Thanks for your help.
