[BETA] Homey Custom Tiles
Updated the code for flows to also get advanced flows:
<script type="application/json" id="tile-settings">
      "schema": "0.1.0",
      "settings": [
        {"name": "token", "label": "Token", "type": "STRING"},
        {"name": "homeyCloudId", "label": "Homey Cloud ID", "type": "STRING"},
          "name": "isFavoritesOnly",
          "label": "Only Show Favorites",
          "type": "BOOLEAN",
          "default": false
      "name": "Homey Flows"
</script>
<!-- Do not edit above -->
<script src="https://cdn.sharptools.io/js/custom-tiles.js"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/axios/0.21.1/axios.min.js">
</script>
<div class="main-content" id="mainContent">Initializing...</div>
<style>
    html, body { margin: 0; height:100%; }
    .main-content {
        width: 100%; height: 100%;
        padding: 0; margin: 0;
        display: flex;
        align-items: center; justify-content: center;
        text-align: center;
        font-size: min(20vh, 20vw);
</style>
<script>
var getAxiosConfig = function getAxiosConfig() {
    return {
        "headers": {
            "Authorization": "Bearer " + patToken
var onClick = function onClick() {
    if (flows.length === 1) {
        //execute the one flow we have
        executeFlow(flows[0].flowId);
    } else {
        var list = {
            title: "Flows",
            items: []
        //build the list from the flows array
        flows.forEach(function(flow) {
            list.items.push({
                label: flow.name,
                value: flow.id
        //show the list
        stio.showList(list).then(function(picked) {
            //if the user picked something, then execute that flow
            if (picked) {
                executeFlow(picked);
var getData = function getData() {
    var promises = [
        getFlowsAndAdvancedFlows()
    if (isFavoritesOnly) {
        promises.push(getUserMe());
    Promise.all(promises).then(function(promiseResults) {
            flows = favoriteFlowIds.map(function(id) {
                return rawFlows[id];
            }).filter(function(f) {
                return f != null;
        } else {
            flows = Object.values(rawFlows).sort(function(a, b) {
                var _b, _a_name, _a;
                return (_a = a) === null || _a === void 0 ? void 0 : (_a_name = _a.name) === null || _a_name === void 0 ? void 0 : _a_name.localeCompare((_b = b) === null || _b === void 0 ? void 0 : _b.name, undefined, {
                    sensitivity: "base"
        //formatting
            content.innerText = flows[0].name;
        } else {
            content.innerText = "Flows";
    }).catch(function(error) {
        console.warn("Error in getData. Probably caught earlier", error.message);
var getFlowsAndAdvancedFlows = function getFlowsAndAdvancedFlows() {
    var urlFlows = URL_TEMPLATE.replace("{{cloudId}}", cloudId) + "flow/flow";
    var urlAdvancedFlows = URL_TEMPLATE.replace("{{cloudId}}", cloudId) + "flow/advancedflow";
    var promiseFlows = axios.get(urlFlows, getAxiosConfig());
    var promiseAdvancedFlows = axios.get(urlAdvancedFlows, getAxiosConfig());
    return Promise.all([promiseFlows, promiseAdvancedFlows]).then(function(responses) {
        var flowsData = responses[0].data || {};
        var advancedFlowsData = responses[1].data || {};
        // Merge flows and advanced flows
        rawFlows = Object.assign({}, flowsData, advancedFlowsData);
        console.error("Error fetching flows and advanced flows", error);
        content.innerText = "Error fetching flows and advanced flows";
        throw error;
var getUserMe = function getUserMe() {
    var url = URL_TEMPLATE.replace("{{cloudId}}", cloudId) + "users/user/me";
    return axios.get(url, getAxiosConfig()).then(function(response) {
        if (!response.data) return;
        userProfile = response.data;
        var flowIds = userProfile && userProfile.properties && userProfile.properties.favoriteFlows;
        if (!Array.isArray(flowIds)) return;
        favoriteFlowIds = flowIds;
        console.error("Error fetching favorites", error);
        content.innerText = "Error fetching favorites";
        throw error; //rethrow the error so the caller doesn't continue
var executeFlow = function executeFlow(flowId) {
    var url = URL_TEMPLATE.replace("{{cloudId}}", cloudId) + "flow/advancedflow/";
    url = url + flowId + "/trigger"; // Use advancedflow instead of flow
    axios.post(url, null, getAxiosConfig()).then(function(response) {
        console.log("Response Status", response.status);
var content = document.getElementById("mainContent");
var patToken = null;
var cloudId = null;
var flows = [];
var rawFlows = {};
var userProfile;
var favoriteFlowIds = [];
var isFavoritesOnly = false;
var URL_TEMPLATE = "https://{{cloudId}}.connect.athom.com/api/manager/";
content.onclick = onClick; //setup the click handler
stio.ready(function(data) {
    console.log("stio library is ready with token", data.settings.token);
    if (data.settings.token == null) {
        content.innerText = "Please configure the tile";
        return;
    } else {
        patToken = data.settings.token;
        cloudId = data.settings.homeyCloudId;
        isFavoritesOnly = !!data.settings.isFavoritesOnly;
    content.innerText = "Loading...";
    getData();
</script>
