So I got the email a little while back about the change. I already pay and a premium member.
This morning it said I had already ran through my allowed API calls and it isn’t even oct 1st yet. What I am trying to figure out is what exactly is the COUNT of API calls I am allowed? Everything I read or search says it varies and I can not just get a count. With a count, I can do the math to see what I have to do. Almost all of my calls would be for Samsung / SmartThings. Is there anyway to get an actual number/count?
It is kind of nuts I have already hit my limit this month if it actually started at the start of this month. I have a group of lights that turn on/off at night/morning. I turn on a few different pumps and what not which are on Kasa’s network. But I believe it is done through SmartThings too. But again, it shouldn’t be a lot. That is why I’m trying to get a count so I can do the math.
Yeah to not even deal with that, I started asking myself how much of what I do with sharptools can be done with smartthings directly thru the API or thru and edge driver (web requester driver for the win here)
In addition I leveraged macrodroid on my wall mounted tablet too, so now there’s stuff where macrodroid directly talks to my kiosk.
It was annoying. But looks like I’ll be waaaay under going forward.
Welcome back to the community and thanks for posting! I would recommend taking a look through the main community post announcing the upcoming SmartThings API Limit change as it has more details about the change including details about how to check your usage and patterns to reduce usage.
The Over Limit email should currently include a note indicating that usage is not being enforced at the moment. I enabled the usage notification this month as another notification to ensure anyone who missed the previous one-off communication was aware.
This allowance is not currently enforced. Your Rules are not blocked; this warning helps you prepare.
Make sure to check the Usage view linked from the notification and described in the community post above. You can access it from your Rule list by tapping the … in the top-right corner and selecting SmartThings Usage. That’s the best way to understand your usage, including which rules are contributing to usage - especially switching between Current Month, Last 7 Days, and Latest Day to get a feel for if changes you are making to rules are reducing usage as expected.
I took a quick look and it seems like more than 98% of your usage is from a single HVAC Temperature calculation rule which is presumably triggering very frequently and the call to set a SmartThings Virtual Temperature device is driving the SmartThings API Usage.
Yes, I did see that after I submitted. I disabled it for now. It is used to determine when to turn on my vent booster fans since we have a large ranch with the furnace on one side of the house. For summer, not needed. For winter, I may have to determine another way to trigger it on/off. Ecobee unfortunately doesn’t update enough with ‘am I running or not’. It is delayed.
But this helps a lot for me to try figuring this out. I’ll watch it with it off to see if I can at least stay below the allowed allowance. Then work my way from there.
